Error 9632 · CNC 8058 / 8060 / 8065 · CNC 8070 · CNCelite 8058 / 8060 / 8065 / 8070
Message: ABSIND: Error when reading information.
Detection
On startup or normal operation of the system.
Cause
The drive has not been able to read the identification of the ABSIND module during system startup. The error is likely due to a malfunction of the ABSIND module or a connection problem between the ABSIND module and the drive.
Solution
Check that the connection and the cables are OK. If the error persists, contact Fagor Automation.
