Error 1220 · CNC 8055 M
Message: Work zone 3 of the Z axis exceeded
Detection
During execution.
Effect
It stops the movement of the axes and the spindle, eliminating all the enable signals and canceling all the analog outputs of the CNC. When detected from the position loop, it opens the position loop and sets the LOPEN mark to ·1·.
If it is in execution, it interrupts the execution of the part program of the CNC of its
Cause
An attempt has been made to move an axis to a point located out of the work area 3 that is defined as "no exit" zone.
Solution
In the program history, work zone 3 (defined with G20/G21) has been set as "no exit" zone " (G22 K3 S2). To cancel this work zone, program "G22 K3 S0"
